Obankenobi
Hypnotoaded
So I was having a near religious experience listening to my 240Ti's one night when I started hearing distortion in one channel. I pulled the midrange and tweeter, ran sweeps through them with the iFrequency app on my iPhone (thanks Zonker) and sure enough, it was the 044Ti. Sounds like something between a "bee buzz" and high pitched "honk" and is most apparent at ~440 Hz. Applying pressure to various places on the face plate lessens the buzz, but it doesn't go away.
I was reluctant to dive in, but after reading some others' posts I adopted the attitude "Its already broken, so what do I have to lose?"
First, off came the heavy aluminum mounting plate:
Then I pried the phenolic plate off the magnet with a putty knife. It was affixed with double-sided tape. Tough to pry while trying to be delicate and avoid damaging the dome or voice coil! Eventually it popped. Everything looked good with the voice coil wire and former
The dome damping foam had deteriorated and crumbled a bit. I've heard about this before. I removed the foam and cleaned up the adhesive with a Q-Tip loaded with orange solvent
Cleaned the back of the dome as well
Noticed some metal shavings in the voice coil gap. I worked folded paper around the pole piece, and vacuumed the gap clean
I read somewhere (probably Troels Graveson's site) that replacing the foam isn't an exact science. Its there to damp and support the dome, and I did my best to cut a new piece out of soft, open cell foam. As is apparent - not precision die cut!
Affixed the new foam and phenolic face plate with - wait for it - Shoe Goo! I threaded the faceplate bolts loosely, then tightened while running a 440 Hz tone with iFrequency.
The operation had all the hallmarks of one of my successful electronic world endeavors (I've had lots of bad ones too... and usually know it). No broken parts, no duct tape... only problem is, even with the VC apparently well aligned, I still get the buzz. Time to take apart again, and maybe start looking around with a magnifying glass.:sigh:
Anybody have any advice or ideas? I'm thinking now that if a finger on the dome lessens the buzz, maybe my foam damping piece needs to be larger and exert more pressure on the dome.
